此补丁MP06也可以从QQ交流群14882199的群空间获取
Dear Solid  Edge Customer:
Solid Edge ST9  Microsoft Installer (MSI) Maintenance Pack 6 is available for download.
Sincerely,
The Solid  Edge Team
Release  Notes:
Microsoft  Installer (MSI) Maintenance Packs – Solid Edge ST9 Maintenance Packs are delivered as and installed using  Microsoft Installer (MSI) technology. Solid Edge MSI based Maintenance Packs  are tracked as Installed  Updates.
Download  Location:
ST9 Maintenance  Packs can be downloaded from:
   [url=]https://download.industrysoftware.automation.siemens.com/solid_edge/ST9/Maintenance_Packs/[/url]
Installation:
Maintenance  Pack .zip files are complete product setups. Therefore, existing versions  must be uninstalled  using Uninstall a program from the Control Panel.
• MSI Product  Updates can be applied on top of the base release and or existing Product  Update with  a lesser version.
• MSI Product  Updates are all inclusive, i.e. fixes delivered in MP3 include all fixes  delivered in MP1  and MP2.
• MSI Product  Updates calculate free disk space before installing. Please note that there  have  been  cases where the Disk Space Computation takes several minutes to complete.  Please be patient.
• MSI Product  Updates can be uninstalled without having to remove the base Solid Edge  product.
• Uninstalling  a MSI Product Update will restore the installation to the state before the  Product  Update  was applied.
• PLEASE NOTE:  When uninstalling a MSI Product Update, the original source media and the  previous  Product  Update package, if any, must be available to allow the recovery of previous  file versions.
• The current  MSI Product Update will be the only Update listed and available for  uninstallation.  After  the current Update is uninstalled, the previous Update will become the  current Update, if  there  were multiple Updates installed.
• MSI Product  Updates are uninstalled via the Control Panel (Uninstall a program –> View  installed  updates  -> Uninstall).
E-mail  Notification:
To receive  direct e-mail notifications for new Solid Edge Maintenance Packs, subscribe  to the SFBmail
notification.
For details on  initiating your email subscription navigate to:
[url=]http://support.industrysoftware.automation.siemens.com/general/email.shtml[/url]
This  Maintenance Pack addresses the following PRs:
===API===
PR 8324311: Exception when PatternOccurrence is selected
PR 7950084: UseGlobalBendRadius is not modifying the CF  feature's to use global bend radius
PR 7936594: A parts list update was incorrect if assembly  loaded
PR 7962044: GetCharCurveCount API returned 0 curves for  some characters
PR 7955506: Cannot Add SheetMetalGage Property through  API
PR 7816060: Frequent crashing in  JAsmTube::ImpIJAsmTube::SetMaterial
PR 7948804: Changing gage through API is not updating the  bend radius values
===Assembly===
PR 7812286: Custom part is added in standard part library  but cannot call through Piping
PR 7918004: Solid Edge crashed while moving the part with  copy option and tangent constraint
PR 7919175: Drag with copy option is working differently  IPA'd -vs- Opened
PR 7898132: Case-specific crash when deleting a part from  assembly
PR 7892218: Cannot change occurrence properties settings  in this assembly
PR 7939113: RMB on pathfinder during edit in place of a  feature doesn't work
PR 7920864: Fixed a crash identified by auto crashlog  capture
PR 7922996: Solid Edge is crashing after creating wire  harness
PR 8528424: Solid Edge is crashing when reopening this  assembly file
PR 7938545: MRU Thumbnail not show for alt assemblies
PR 7967585: Solid Edge keeps crashing randomly
PR 8327420: Crash when exiting sketch after placing a  block
PR 7969451: Abort in relationship tree when selecting a  certain relationship
PR 7972055: Solid Edge crashed when applied sensors - Win  10 specific
PR 8323188: Frequently crash working with Solid Edge
===Draft===
PR 7783355: Crash when updating views on a file with  missing component
PR 7886994: DWG is not correctly translate with Solid  Edge
PR 7908506: Can't Attach/Detach radial dimensions using  Alt + drag
PR 7920509: Breakline creation fails if keypoint is  selected from previous region
PR 7918120: Aspect ratio of sheet changes as length  exceeds 109.22 inch
PR 8324292: Dimension lines of Angular Dimensions are  imported much too large
PR 7789711: Changing scale of view does not change scale  of principal view with break lines
PR 7904338: Dimension style doesn't preserve  Annotation-connector line type
PR 7931370: Dimensions deleted when centerline is moved
PR 7946095: Windows re-indexes all items after installing  SE
PR 7944009: SE crashes when moving an aligned and grouped  drawing view.
PR 7958506: Balloons don't update after changing item  number via put_ItemNumber
PR 7928057: Dimensioning detail views
PR 7937124: Cannot get reference key for silhouette edges
PR 7945104: Column with multiple property texts is not  sorting correctly
PR 7970209: ST8 draft file aborts when opened in ST9
PR 7945679: DV/PL do not go OOD when user adds/removes  occ property overrides
===Part/Profile/Sheet Metal===
PR 7926588: Solid Edge crashes after getting area of  sketch
PR 7858006: Cutout will stop if dynamic preview is OFF
PR 7889432: Unable to Delete imported Wireframe without  hiding first
PR 7901408: Link to material leads to a crash on update
PR 7920601: Variable values in ST9 Ft-In 0 is not there
PR 7868004: summary of atomic parts shows assemblies
PR 7928935: The Subject is not available in the tab  Details of the properties on the OS
PR 7931593: Auto dimensions are getting marked as in  error
PR 7940215: Tear-off command crashes Solid Edge
PR 7938629: Crash at  'JMSetManager::AddToSubsetWithSameMpartOwner'
PR 7915615: Unable to select copied sketches with  manipulation commands
PR 7916470: Drag and drop is not supported on simulation  studies
PR 7929149: Performance time increase when applying  material to a part
PR 7940333: Solid Edge crashes when sectioning the  extrude feature
PR 7920410: Solid Edge crashes editing a component of an  assembly
PR 7939535: Cannot flatten sheet metal of Part-Copy
PR 7945373: Normal Cutout Thru All gives failure warning  even though it succeeds
PR 7904897: save file causes a 'cannot access file'  message... 2 times out of 3 when saving to a server
PR 7913897: API Exception when hole collector will be  selected instead hole features
PR 7908712: The shape of Flat Pattern is incorrect.  Please correct in SE ST8 MP
PR 7959342: Flat Pattern will not be created correctly
===General===
PR 7858083: Incorrect behavior when user defined  templates exceed sixteen files
PR 7892075: Creating new theme with commands in QAT  results in slow sketch lines
PR 8313169: Path for 'User templates' does not update in  'Fast property search'
PR 7892297: Cannot create the folder c:\Users\User  B\Appdata\ when starting Solid Edge
PR 7939613: Custom program using SEDraftX.ocx results in  blank buttons
PR 7913560: Solid Edge is crashing frequently...Crash  logs for Dev Review
PR 7666914: Defining keyboard-shortcuts will mess up  configuration
PR 7925373: Further File Open and File New performance  improvements
===Design Manager===
PR 7849732: Design Manager tries to rename the folder  path
PR 7940999: Design Manager duplicate file name error  indication
===Built-in Data Management===
PR 7905132: Fast search, Search tool does not work if  "Look in folder" use a mapped drive
===Insight===
PR 7928903: LCA Error Message with strange characters for  checked out documents
PR 7882183: Parts not displayed when asm will be loaded  as simplified and then as designed
PR 8325252: Parts not displayed when asm will be loaded  as simplified and then as designed
PR 7886563: Released Documents can't be moved back to  available
PR 7870628: LCA's apply status to linked documents option  not using the options.xml.
PR 7939490: Property Manager removes all material  definitions in French version
PR 7972514: Material change with Phys. Property Manager  clears materials for parts
===Solid Edge SP, Server, Standalone Client, Solid Edge  Client===
PR 7930745: CPD column widths continually increase each  time an upload/check-in is performed
===Teamcenter Integration for Solid Edge===
PR 7884971: Create a draft from part while showing  vertical prop window errors
PR 7915586: Custom Property in SEEC File Properties has  limited string value
PR 7921892: Update of Property Text in SE Draft requires  opening model file
PR 7926338: Modify value in CPD master=cad property does  not change attribute in RAC
PR 7803149: Add to Teamcenter Interactive crashes when using  the function "Find all related Drafts"
PR 7927588: Customer has some family of assemblies where  the API to list properties in ST9 is very slow
PR 8326383: NULL value is not sync'ed with /master=cad
PR 7866423: Canceling the Login menu with custom template  list active forces multiple cancel
PR 7875837: Add to Teamcenter crashes
PR 7891459: Problem with Attribute Mapping on SE Draft
PR 7916950: Add to Teamcenter Interactive does not accept  'units' in Density attribute
PR 7927661: German Callout for Filename is not working  correctly
PR 7921740: Save As, if the project is cleared then  cancelling project dialog re-populates
PR 7925504: Multiple crashes when editing blocks, crash  occurs in EditBlockView
PR 7945874: Check In All cause BOM view crash
PR 7948241: Save As from SE Draft loses Material already  assigned to original Part Rev
PR 7950067: Drawing views linked to SE Draft Dataset from  same Item Rev
PR 7957318: Non-graphic Parts in SEEC and Teamcenter not  working with ST9
PR 7958783: “Teamcenter has defined unique Item  Numbers" due to Alt Pos Assy usage
PR 7966653: JT Part Properties are populated to Solid  Edge Assembly Properties
PR 7977369: Copying a JT-component in SE Assembly does  not trigger SEEC BOM
PR 7992576: Replace Part command is not working for  JT-based Driven References
===Translators===
PR 7787919: Error of translating to IFC with enabled  option 'Export displayed only'
PR 7929985: ST9 can’t open STEP file
PR 7907191: When exporting draft files to AutoCAD, the  unwanted line weight now shows up
PR 7915468: Getting Error "The migration has been  terminated"
To access the current Edge Answers, Employees and Partners can  click the following link.
[url=]https://sales.industrysoftware.automation.siemens.com/news/int/34/Solid-Edge-Answers[/url]
Happy selling!!
Mark Thompson
  Senior Application Engineer
  Global Technical Business Development
共 1 个关于本帖的回复 最后回复于 2019-5-16 00:01
