Solid Edge ST10:Shaping the future of product development
Solid Edge ST10:塑造产品开发的未来
The Solid Edge ST10 portfolio of products from Siemens brings every aspect of your product development to the next level. It gives you the very latest in next generation design technologies, fully integrated flow analysis, the newest tools for 3D printing and more options for creating technical publications. You’ll have perfect control of design data at any scale, along with a brand new way to collaborate securely on the cloud.
来自西门子的Solid Edge ST10产品组合将您的产品开发的各个方面提升到一个新的水平。 它为您提供最新的下一代设计技术,完全集成的流量分析,最新的3D打印工具和更多的创建技术出版物的选项。 您可以完美地控制任何规模的设计数据,以及在云端安全合作的全新方式。
Benefits  优点
Seamlessly work with mesh models alongside traditional 3D data without time-consuming conversions
无缝地使用网格模型以及传统的3D数据,而无需耗费时间的转换
Minimize mass and material usage using automatic topology optimization
使用自动拓扑优化最小化质量和材料使用
Interact naturally through free hand pen sketching; break the mouse barrier
通过自由手笔自交互草图; 打破鼠标的障碍
Accelerate work within large assemblies
加快大型装配中的工作
Print 3D designs on local devices or submit them to a global network of 3D printing services
在本地设备上打印3D设计或将其提交到全球3D打印服务网络
Perform fluid flow and heat transfer analyses to optimize product performance and reliability
进行流体流动和热传递分析,以优化产品性能和可靠性
Publish effective technical illustrations and manuals directly from Solid Edge models
直接从Solid Edge模型发布有效的技术说明和手册
Built-in Solid Edge data management is even easier to install and even more productive
内置Solid Edge数据管理更容易安装,甚至更高效
Wider support for part classification, working offline and engineering-to-order processes when working with Teamcenter
与Teamcenter合作时,更广泛地支持部件分类,离线工作和工序到订单流程
Collaborate easily with suppliers and customers using cloud-based vaulting, viewing and markup
与供应商和客户轻松协作,使用基于云的存储,查看和标记
Reverse engineering 逆向工程
Many teams design products utilizing components imported from other CAD systems. With the rapid growth of high-resolution 3D scanners, even legacy parts designed on the drawing board can be digitally represented and modified to suit contemporary designs without complete reconstruction. Solid Edge delivers tools that speed your reverse engineering workflows.
许多团队使用从其他CAD系统导入的组件设计产品。 随着高分辨率3D扫描仪的快速发展,即使在绘图板上设计的传统零件也可以进行数字化表示和修改,以适应现代设计,而无需完全重建。 Solid Edge提供了加快逆向工程流程的工具。
Simulation 仿真
Solid Edge Flow Simulation is a fully embedded and intuitive computational fluid dynamics (CFD) analysis tool that provides a wide range of users with valuable insight into product behavior from the beginning of the design cycle. The tight integration between native Solid Edge geometry and simulation data makes certain that all changes are synchronized, resulting in optimized product performance and reliability earlier in the product development process.
Solid Edge Flow Simulation是一种完全嵌入式和直观的计算流体动力学(CFD)分析工具,可为广泛的用户提供从设计周期开始就对产品行为的宝贵洞察。 原始Solid Edge几何和仿真数据之间的紧密集成确保所有更改都是同步的,从而在产品开发过程的早期提供优化的产品性能和可靠性。
Technical publications 技术文档发布
Solid Edge ST10 enables fast publication of manufacturing and assembly instructions, training manuals, spec sheets and more. Solid Edge llustrations software creates illustration sets directly from Solid Edge geometry and product and manufacturing (PMI) annotations, while Solid Edge Documentation generates customizable, multi-page documents. The interoperability between these tools allows seamless creation of step-by-step process instructions from exploded views and multiple product configurations ‒ even permitting use of multiple 3D models in a single document. Edits to Solid Edge models can automatically propagate to the publications.
Solid Edge ST10可以快速发布制造和装配说明,培训手册,规格表等。 Solid Edge llustrations软件直接从Solid Edge几何和产品和制造(PMI)注释创建插图集,而Solid Edge文档可生成可自定义的多页文档。 这些工具之间的互操作性允许从分解视图和多个产品配置无缝创建分步过程指令,甚至允许在单个文档中使用多个3D模型。 Solid Edge模型的编辑可以自动传播到出版物。
共 0 个关于本帖的回复 最后回复于 2017-5-19 11:09
