勘探钻头取芯钻井,原理图如下。取一个薄体流域为动域,其它液体为静域。截取模型的1/8,设置周期性边界(两对周期性边界,采用压力梯度设置)。采用滑动网格模型,FLUID-动域设置为Mesh Motion,动域的内壁设置为Moving Wall,动域和静域间用Interface连接。动域和静域分别设置速度入口和自由出口。计算时出现了问题:Divergence detected in AMGsolver: pressure correctionDivergence detected in AMGsolver: epsilonDivergence detected in AMGsolver: temperatureturbulent viscosity limitedto viscosity ratio of 1.000000e+10 in 60934 cells Primitive Error at Node 0:floating point exceptionPrimitive Error at Node 1:floating point exceptionCas文件如链接http://pan.baidu.com/share/link?shareid=4057872408&uk=488149318[img][/img]
共 2 个关于本帖的回复 最后回复于 2013-8-15 10:28
